주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
로지텍 MX 마스터 2S 무선 마우스 수리 및 분해 정보입니다. 2017년에 출시되었으며 모델 번호(M/N) M-R0066 또는 부품 번호(P/N) 810-005769, 910-005138, 910-005137 또는 910-005131로 식별됩니다.
Right mouse click is not working
Hello,
my right mouse click suddenly stopped working on my MX Master 2s.
I tried following steps without any success:
1) Turned mouse on/off
2) Connected mouse via bluetooth dongle on other computer
3) Switched left/right mouse click via Windows settings
4) Bought a new original mouse click switch (from Omron) and replaced the old switch
-> After all my right mouse click is not working!
-> I now use a wired, old mouse and I have no problem at all with this.
Can you please help me?
Do you think it might be a hardware malfunction on the motherboard?
I mean I even replaced the switch.
Thanks,
Fabian
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Same issue here, is there any kit for solving this in Ifixt?
댓글 달기
답변 2개
가장 유용한 답변
Have you checked the top "activator plate", of the mouse that activates the switch uppon depression of the mouse buttons? It sounds like the there may be a gouge in the "activator plate" which prevents the plate from making contact with the switch.
이미지
If you do see this I used some hot glue and filled in the gouge on an MX master 3 and its been going strong for a few months now. But you can also use other fillers to get better results.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Hello Zach,
thank for your help. Unfortunately this did not help. The "activator plate" has full contact to the switch. I even demounted the upper shell of the mouse and clicked on the switcc directly with my fingers. The right mouse click gives a nice snappy accoustical feedback, yes, but there is no response on my computer. In my opinion there must be a hardware malfunction on the motherboard.
Well I don't know what to now. Seems to be broken, unrepairable.
이미지
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Mr. Mouse 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 50
전체 시간: 4,891
