주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2018년 10월 26일 출시. 모델 A1984, A2105, A2106, A2108. GSM 또는 CDMA / eSIM, nano-SIM 또는 듀얼 SIM / 64, 128, 256GB / 블랙, 화이트, 블루, 옐로, 코랄, 레드 색상으로 출시됨. ("아이폰 텐 R"로 발음함.)
iPhone XR VDD Main Short
iPhone XR came in being stuck in DFU mode, supposedly water damage, I have opened the phone and inside was no traces of water damage ( I have checked under the shields also), tried unplugging each individual connector still same, at last I flashed the phone through 3uTools it went good without any error codes, after the flash I tought the phone will boot but it went completly dead, not drawing any current, I have checked VDD main line and it's shorted to the GND, tried injecting voltage but nothing is heating up, looked up under the microscope everything seems good, I have reballed the PMIC(after I removed it the short was still present) I'm all out of ideas and thinking of doing a swap
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
If it is not drawing any Amps you do not have a VDD main short.
의
댓글 달기
답변 1개
선택된 해법
hello there,
look at the vdd-main line diagram (you need a schematic). Start by removing the power supply bridge (R3303). This will solve a lot of your problems. In general, the line is quite straight as like for Apple and you should have no trouble finding the short (use the TP0540 test pad). Anyway, you have got dwo diferent sub-circuits of power supply: The North with all system supplied and The South - just charger with pp_bat and i2c services for main battery. Thats all. More similar casesys you can find on my (free of charge) repair blog. Just read, ask if not understanding and learn. Details can find "about me" tab.
-fingers crossing,
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
I removed R3303 and the short was gone, but out of pure frustration I already desoldered CPU, NAND and other paired components 🤦
의
Did you replace it?
의
Hey, it's not a matter of replacing the r3303 alone. It's just a combination of two cooperating sub-systems. Temporary removing it from the environment allows you to narrow the search area only to the passive or active side of powering.
의
댓글 달기
답변을 추가하세요
Em4N 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 9
지난 30일: 35
전체 시간: 861
