주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OnePlus 8 Pro는 2020년 5월에 출시된 OnePlus의 안드로이드 스마트폰입니다. 이 페이지에서는 지역 모델 IN2023 및 안드로이드 빌드 명칭 OnePlus8Pro를 다룹니다.
Fingerprint Sensor Not Working After Screen Replacement
So yesterday I had my screen replaced (was grenaded after it met my bed frame edge) and it all went perfectly fine. The only thing that bothers me now is the fingerprint reader. I can register new fingerprints without a hitch like normal, so I know it's working fine, but after setup my fingerprint just doesn't work, like something is suddenly making it not read. Has anyone else ran into this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 7개
가장 유용한 답변
If you transferred the original finger print sensor from the old display to the new one, it typically requires recalibration. If not, then the finerprint sensor is programmed to that specific device and a new or replacement one won't work without reprogramming it. As far as I know, oneplus doesn't make the reprogramming software publicly available. Thanks, OnePlus!
This one on eBay should do the trick https://www.ebay.com/itm/275420607111?ch...
This guide should help as well https://www.youtube.com/watch?v=FsZFyGXc...
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
Oh wow, that's odd. I would've thought that with the sensor being in-built that it would just be plug and play like the display and literally every other capacitive thing with it. I haven't tried the usual troubleshooting like rebooting and such (and I'm not factory resetting this phone unless I'm selling it). Guess I'll see where the links you provided get me. Is that same tool available on Amazon by chance?
의 공유
If you can register new prints have you removed any old prints then tried again?
의 공유
@razorx you'd think it would work like that but no. I haven't seen it on amazon but it's worth a shot to check
의 공유
How can you reprogram the fingerprint sensor?
의 공유
댓글 달기
OnePlus said that no calibration is necessary after installing a replacement screen and digitizer on the OnePlus 8 Pro. Current as of 06/10/2023.
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
@schleems18 it must be necessary surely. Otherwise how does my fingerprint register fine but never works in practice?
의 공유
I haven't attempted changing or adding a new fingerprint, everything functioned as it had before the screen replacement. Have you tried a factory reset? You could also try adding the same finger a couple times, just in case.
의 공유
@schleems18 I'd much prefer not factory resetting, I don't want to go through the faff of recovering everything. And I did try adding a couple times, no avail. As of late I've just been living without it
의 공유
I'm facing the same issue
의 공유
댓글 달기
phone display not on
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
how to on phone dispaly
의 공유
댓글 달기
Fingerprint issue
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Fingerprint scanner issue
의 공유
댓글 달기
Will it work after a hard reset??
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have faced that problem after display Replacement in oneplus 8 pro. Any solution here plz?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
fingerprint not working
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Razor X 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 18
지난 30일: 67
전체 시간: 10,193
