주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2010년 3월 북미에서 출시된 Nintendo DSi의 더 큰 버전입니다. 대부분의 수리는 스크루드라이버와 수리 도구만으로 가능합니다.
Why is my dsi doesnt charging?
i tried to charged my dsi at first but the charging light doesnt turning on. but my dsi xl is showing it was charging, i thought it was just some error. but then after 2 hour, i noticed that the battery percentage is still at 50%, so i tried changing another place to charge but still not increasing. what do i do? should i change the ac adapter or change the battery or something?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
For posterity,
TL;DR - Component U11 is faulty.
I have a console with that exact problem. After fixing the female battery connector that was ripped off the motherboard board, I noticed both the positive and negative were shorted, which was very odd since it wasn't my solder job. Cross-checking with board schematics, I noticed that pins 9 & 10 on component U11 were shorting to GND on pin 4. Pin 9 & 10 were connected to the positive pad of the battery connector, so they shouldn't be shorting to ground like that. Replacing U11 from a donor board fixed the issue.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
To add: If that didn't worked, you can try to test with a new battery. But most likely it's just the U11 causing this.
의 공유
댓글 달기
답변을 추가하세요
raihan kavindra 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 62
전체 시간: 382
