주요 콘텐츠로 건너뛰기
Announced in August 2017년 8월에 발표된 Galaxy Note8을 회수된 Galaxy Note7의 후속 모델입니다. Note8은 대중이 구매할 수 있도록 2017년 9월에 공개되었습니다.
145 질문 전체 보기
Where to get a replacement charging-port (USB-C) assembly?
I got a Galaxy Note8 phone, and lately I have had problems connecting the charging/data cable (tried several different ones). The connector seems like it's connected, but the connection is wonky (especially when trying to transfer data) and it falls out if you look at it wrong. When trying to charge, I often get the "not charging correctly" error. As I need to replace the battery (real!) soon anyway, I'd like to replace the charging-port assembly at the same time. I understand the jack-contact is modular and can be swapped over to the new assembly.
Anyway, may real question is where can I find/source a (preferably new) replacement charging port assembly? I couldn't find it for sale here (unlike the battery). I'd rather pay a bit more to get it from a reputable source, than from some dodgy dealer on Amazon or eBay... And I need it shipped to Europe.
Is this something iFixIt could get for me from a reputable source?
PS: In a pinch - if it was available from somewhere - I could change the actual USB-C port contact if it's at all possible... it wouldn't be the first time I soldered SMD components...
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @koppe
Here's just one supplier that may be suitable.
If not search online for GH97-21078A GH97-21067A to find suppliers that suit you best.
If you wish to replace the board yourself, here's a video that may help.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Sounds more like your charge port is full of dirt and needs cleaned out. Use a needle to gently work round the bottom of the port keeping away from the centre post. Lift any dirt out, the do either end to remove any left over from the sides.
댓글 달기
귀하의 답변을 추가하세요
Koppe 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 30
