주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2022년 Apple의 최고급 플래그십. 9월 16일에 출시된 iPhone 14 Pro Max는 6.7형 ProMotion OLED, 새로운 Bionic A16 칩, 트리플 후면 카메라 시스템, 5G 연결성을 자랑합니다. iPhone 13 Pro Max의 후속 제품입니다.
How to remove iCloud Activation Lock?
I bought an iPhone 14 Pro Max on facebook for cheap, and I was wondering if there are any ways to remove the iCloud lock. I contacted the seller and had no hope.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 12
댓글 7개
Do you wanna sell it ? I need it for parts
의
Yes I can sell mine ITS Iphone 14 pro max used good battery health
의
How much are you asking for?
의
@mohamedali30854 and @timhardy57639 make sure you finalize your deal by email in the next few hours. After that your buy/sell offer will be deleted. We are a self help forum and do not want to start a swap meet here.
의
Thank you @oldturkey03. Dalyattaoui@gmail.com
의
댓글 2개 더보기
댓글 달기
답변 4개
선택된 해법
Not without the involvement of the person whose account the phone is locked to, or the original owner of the device. So you would need to coordinate with the seller (assuming they are they are the genuine owner). The will need to remove the device from the list of Find my Devices in iCloud, or if they cannot do that for whatever reason—forgotten password, don't have access to recovery e-mail or phone any longer,etc..., they can submit the original proof of purchase to Apple to have them unlock it.
Otherwise it's stuck as is. A major hazard of buying used devices, sadly.
이 답변이 도움이 되었나요?
점수 15
댓글 1개:
how to remove iphone 14 pro max activation locked ios26.6.1
의
댓글 달기
you will need to contact the previous owner and have them login to the icloud account and remove the association, either on the phone itself, or via either www.icloud.com or appleid.apple.com.
beyond that there is no permanent solution.
yes, you will find services and software offering to remove icloud accounts, it's all BS. these "solutions" involve jailbreaking the phone then installing a "bypass". but the phone will not behave like a normal phone (if i'm misstating some of these items, i welcome correction as a am not a jailbreaking expert). you will likely have issues with downloading and installing apps, you may have issues trying to use the only on you cellular service account, you cannot do auto upgrades the IOS, your device becomes more vulnerable to malware/hacking, battery drain/usage increases dramatically, it makes the overall IOS environment less stable meaning more crashes, and if you do upgrade the IOS or reset the phone, you have to re-jailbreak it again.
using jailbreaking to "fix" an icloud account is like (you may be too young to actually relate to this) watching TV before they had remote controls. you want to change the channel or change the volume or adjust the rabbit ears, you had to get out out of your chair, walk to the tv and do so manually - every time. sure it all worked, but it was horribly inconvenient compared to what a modern day TV remote can do for you.
if anyone has a better analogy, i welcome input on that regard as well. :)
bottom line, the only way to properly remove it is to have the icloud account owner do it
이 답변이 도움이 되었나요?
점수 6
댓글 2개:
How to remove I cloud
의
@mulalomudau you can't unless you have the previous owners credentials. Check the accepted answer.
의
댓글 달기
can you help me for unlock icloud iphoen 14 pro mex
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Activation lock without owner
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Lucas Pop 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 9
지난 7일: 47
지난 30일: 232
All Time: 11,942
