주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
10세대 Apple iPad 수리 안내서, 분해 및 문제해결 정보를 제공합니다. Wi-Fi 및 셀룰러 모델로 출시되었으며, 64GB 또는 256GB 저장 용량을 갖추고 있습니다. 2022년 10월에 출시되었습니다. 모델 번호 A2696, A2757, A2777 또는 A3162로 식별할 수 있습니다.
Heating issue/screen brightness effected
Could it be possible to give me the dimensions of where the logic board is so I can place some heatsinks to try and keep ipad cooler so the screen don't keep reducing brightness. I'm sure it's a heat issue as once temperature is reduce the brightness of screen returns to normal.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Here's a picture of the iPad 10 without the screen. I've marked out the logic board in the picture; basically if you cool the right edge of the iPad that's where the heat is going to be coming from.
이미지
The picture is oriented so you'd be looking at it with the charging port on the bottom.
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
cheers. Planning to use akasa double-sided thermal conductive tape. I have plenty of small chipset blue heatsinks that should help handle the heat. Poor cooling design on expensive device. Apple solution is to close down apps to reduce processor usage which bring down heat.
의 공유
@robmods you might want to consider using a 0.3 mm Copper Shim Thermal Pads and some Kapton Tape with your heatsinks. Typically these are used for copper modding graphics cards, but I'm willing to bet that they would work really well in your iPad.
의 공유
댓글 달기
답변을 추가하세요
Robmods 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 13
전체 시간: 533
