Replacing USB connector for USB Cable
Hi, I bought some USB connectors to replace a broken USB connector. Question is the plastic housing doesn't have any lock or clip! Not sure if I need to glue this in or use another method? Thanks.
좋은 질문입니까?
좋은 질문입니까?
Where did you find it? The site or packaging should have offered instructions. It’s possible they are expecting it be potted (hot glue) or a crimp of some sort.
I would need the parts info and a few more pics to offer any other help here.
FYI - This is a USB 2 connector it doesn’t offer the added connections for USB 3
이 답변이 도움이 되었나요?
https://www.aliexpress.com/item/32916600...
USB Cable is from a ring light so only need power!
@analyzer82 - Not sure if potting is the right answer here. I’m suspecting you want to use cyanoacrylate glue (Super Glue) after you have fitted the core in fully tested as this will be a permanent!
I would have used this connector https://www.aliexpress.us/item/225183272...
At least then you could open it up to fix it.
I'll try to Glue. Thanks.
@analyzer82 - Don’t forget to accept the answer - Thanks!
지난 24시간: 2
지난 7일: 4
지난 30일: 25
전체 시간: 542
