주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1998년형 모델은 오리지널 Beetle을 기반으로 제작되었지만, 이전 모델과 비교했을 때 훨씬 더 넓은 실내 공간을 갖추고 있으며 더 발전된 기능들이 탑재되어 있습니다.
Check engine light on
Catalytic converter code I don't have $1000 dollars to spend on my car am a single mother w a disabled son I need help on the cheapest way I can fix it myself plzzz help
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi Ms. Ali,
I've had cat codes on my '99 Beetle, and it doesn't always mean a thousand dollar repair. Some of the codes can be alleviated by replacing the oxygen sensors that detect the functioning of the catalytic converter rather than replacing the cat itself. It's gone both ways on my bug; I got the codes to go away by replacing oxygen sensors, but eventually I ended up having to replace the cat itself. But even that doesn't have to cost so much; I bought an aftermarket cat from a reputable manufacturer - Magnaflow and Walker are both good brands - and had a shop weld the replacement in for far cheaper than $1000.
Specifically what code or codes are you getting on your car? What year is it? Is it a Turbo model?
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Ms Ali 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 21
전체 시간: 277
