주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2000-2006년형 BMW X5 모델은 BMW의 1세대(E53) 스포츠 크로스오버 시리즈입니다. X5는 2000년형 모델로 1999년에 처음 출시되었으며, 자동변속기 또는 수동변속기가 장착된 상시 사륜구동 방식을 채택했습니다.
Intermittent wipers don't work.
The medium and high speed front wipers work as they should. None of the intermittent speeds work. The wipers do operate one time in each setting, but not at all after that. The windshield in front of the sensor is clear.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Hi @rickbulwicz
Unless it's a problem with the wiper switch assembly (seems unlikely that it would affect all of the intermittent speeds though) it could be a loose harness connection (at either end, wiper switch assembly or module) or a problem with what is known as the general module.
Here's an image from the 2002-2006 BMW X5 service manual, showing the wiring connections and the location of the module.
이미지
(click on image)
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thank you @jayeff! I'll get my multimeter and start poking around.
의
댓글 달기
If you don't need the "rain-sensing" part, and would be OK with just intermittent wipers (3 speeds), then you can get that easily. I had the same problem with my '02 X5. First, separate the plastic shell around the base of the rear view mirror. Then just unplug the cable from the rain sensor. Replace the shell carefully. You now have basic intermittent wipers, available at the wiper stalk, minus the rain-sensor. THAT'S IT!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Rick Bulwicz 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 44
전체 시간: 1,326
