주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1994년부터 2009년까지 가와사키(Kawasaki)에서 생산한 2세대 Kawasaki Ninja 500R입니다. 일부 시장에서는 EX500 및 GPZ500S로 불리기도 했습니다.
No start just clicking
Stopped it from blowing fuses but still clicking no start
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
Does the click comes from starter? or from the relay?
I had the same problem, would hear a click but no turning whatsoever form the starter motor, after a bit of unrecalled troubleshooting I ended up on starter motor, removed it, opened it, and indeed the brushes were done for, no problem, ordered new ones for a few bucks, soldered them into place and it's starting fine ever since, even though I only used electronics solder and didn't bother welding/jbwelding the connection (still a little afraid that the solder will crack with vibrations and I'll have to open the starter again).
Since you're opening the started engine, grab a caliper and measure the commutator diameter, normally the brushes erode first, but the commutator also erodes and the diameter needs to be within specs, then don't forget to clean the brushes side and grease the gears side. Check the Haynes manual for these models it breaks down step by step of removal, disassembly and inspection of the starter motor.
If you don't want to go through the trouble of removing carbs/airbox and starter, maybe you can open the flywheel window, plug a socket with an impact wrench to the stator and spin it (to the right direction), but I'm not sure if that's a better alternative...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Iam going to try that thanks
댓글 달기
답변을 추가하세요
Fanboys of the Round Table 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 13
전체 시간: 571
