주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toshiba Satellite L50D-B는 Satellite 컴퓨터 제품군의 일환으로 판매된 노트북 컴퓨터입니다.
How to remove the internal SSD?
The internal SSD is not using the normal SATA connection, I have the backplate off. There are rubber corners around the SSD too.
Update (05/28/23)
이미지
. Photo
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
I added a photo but I am unsure if it posted.
댓글 달기
답변 1개
선택된 해법
You should be able to just slide it out as shown in the attached picture. After you pull it out, you may find that the drive really is a SATA drive, just connected in a wonky connector. I was taking apart a laptop the other day that had a ribbon cable attached to an adapter that attached to a SATA connector on the drive. Just give it a go and let us know how it goes.
Good luck!
이미지
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
That works thanks!
You're very welcome! I'm glad my tinkering was able to help someone! :)
댓글 달기
답변을 추가하세요
SaltyAsterisk 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 19
전체 시간: 420
