주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
제빵기에 대한 수리 가이드 및 정보입니다.
Can the computer program be reset?
I have a Kenmore bread machine, the computer needs to be re-programmed.
Update 6/9/23
It's a Kenmore; model 6G22, I think?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 4개
@janetschuroll what exact model is your Bread Maker? What happened to it that makes you think it needs to be reprogrammed?
의 공유
When I turn it on, it starts in the middle of the mixing cycle.
의 공유
의 공유
I have the same issue with my Gorenje bm1600wg bread maker.
The 15 and 16 manual programs are failed to operate. After selecting one of them it's skipped to the next program.
I need a hard reset method for this machine. Pls help me!
의 공유
댓글 달기
답변 1개
선택된 해법
It can likely be reset by following the instructions below. Most of the bread machines I have used follow the same sort of reset process. If you provide the brand and the model you have I can research the correct reset method. This information will also come with the instruction booklet that came with your machine. If you have that handy.
Press and hold the Stop/Start button for ten seconds to cancel the program. If this is ineffective turn the bread maker off at the power for twenty minutes and the bread maker will reset.
I hope this helps.
Monte
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
It's a Kenmore; model 6G22, I think? Looked in the manual I got, didn't see any help there. Will try your solution in the morning. Thanks.
의 공유
Thanks so much for getting me out of that dilemma! It worked.... Very grateful!
의 공유
댓글 달기
답변을 추가하세요
Janet Schuroll 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 34
전체 시간: 1,564
