주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OnePlus 9 5G는 2021년 3월에 출시된 중급형 스마트폰입니다. OnePlus 8의 후속 모델로, 6.55인치 120Hz Fluid AMOLED 디스플레이를 탑재하고 있으며 Qualcomm SM8350 Snapdragon 888 5G 칩셋으로 구동됩니다.
LE2117 Battery replacement options?
Hi, looks like the BLP829 battery sold for the Oneplus 9 5G does not have the Tmobile variant (LE2117) listed as a compatible model. I haven't had much luck finding a Tmobile specific battery for this device, does anyone have any recommendations or know if the BLP829 will work on an LE2117?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
Hey Zed I currently need to replace my LE2117 & OnePlus refuses to do it even with me offering to pay the labor and parts fees. I was wondering if the replacement battery is still holding up? And if so, did it seem new after initially installing it?
의
댓글 달기
답변 2개
선택된 해법
Hi, the BLP829 battery will not fit in a model LE2117 for T-Mobile in the US. You may need to find a different battery model that is compatible with your device. You can use the Oppo BLP821 battery2, which has the same voltage and capacity as the BLP829 battery, but you should check the dimensions and connector type before buying it. Alternatively, you can contact OnePlus customer service and ask them for a recommendation or a replacement service.
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
Thank you, i ordered the Oppo BLP821 and it fits and functions perfectly.
의
From where did you purchase it?
의
Thank you Zed for confirming the BLP821is the right replacement battery for my One Plus 9...LE2117 phone. It's definitely saved me a lot of time and frustration.
의
댓글 달기
Hi Zed, the BLP829 battery won't fit in a model LE2117 for T-mobile in the US. You can use the Oppo BLP821 battery which has the same voltage and capacity as the BLP829. I hope this answer can help you.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank you Holly, for that valuable information because I was about to purchase the wrong replacement battery. I research to find the right replacement battery and Google said I needed the BLP829. I am glad I read the comments before I place my order.
의
댓글 달기
답변을 추가하세요
Zed 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 42
전체 시간: 2,588
