주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
삼성 갤럭시 A22 5G는 갤럭시 A 시리즈의 일부로 삼성전자에서 개발 및 제조한 중급 안드로이드 기반 스마트폰입니다. 이 휴대폰은 2021년 6월 24일에 처음 출시되었습니다. 이 전화기에는 트리플 후면 카메라 설정과 90 Hz 디스플레이가 함께 제공됩니다. 배터리는 5000 mAh로 iPhone 13 Pro의 배터리보다 62% 더 큽니다.
Sound and camera not working
So. I dropped my phone,replaced my screen (I have experience with replacing screens) and after turning the phone on I can't access my camera app or sound. When I open my camera it says "couldnt open try again" I've tried the standard fixes. Cleared cache, safe mode, factory reset, tried disabling camera. I don't have Bluetooth on I have no idea whats wrong. And I can hear sound when I plug headphones in but none without. I have taken it to a repair shop which was no help he just offered to get a new phone which I cannot afford so please help !
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 10개
가장 유용한 답변
Here is the pic hope it is clear enough. @strongbow
이미지
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hello, I have had the exact same issue before. I replaced the earpiece part and the front camera part and it worked perfectly fine. It’s damaged during transferring the old parts to the new lcd. Even though there was no visual damage.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Hello. I have replaced the earpiece part and still no sound. I have also replaced the bottom speaker so was wondering what the next step would be to fix this phone
의 공유
@kuro24592 is it possible to post a good pic of the phone without without the back or plates on?
의 공유
댓글 달기
Try cleaning the back of that top board and speaker with isopropyl alcohol 99.9% and disconnect the camera and clean under both the connector on the camera and the motherboard.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thank you ill order some and try it. what do you think the issue could be?
의 공유
댓글 달기
The speaker bit in the middle at the top can be popped out with a mini flat head screwdriver and cleaned then just pop it back in the same way but make sure the two gold pins face the same way they were before removing.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I think it’s just residue left over in the connection between the board, speaker and camera as they are all gold contact connections if if they are even the slightest dirty or damaged they will not work due to an unstable connection.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
well the earpiece was recently replaced so shouldnt be dirty. do you think it may be a short circuit in the motherboard or just most likely dirty?
의 공유
댓글 달기
이미지
이미지
[br
@kuro24592 The ear speaker is in the wrong way lol. The two springs that are at the very top should be contacting the two metal plates on the corner of the circuit board. Lift it out rotate it 180 degrees the put it back in. When you put the board back in it should sit against the two sprung points. Also try disconnecting the cameras and re seating them as they look like they're not on properly. The area circled in the picture could be your problem. Looks like some components could be shorted.
The tip of the connector arrowed should be under the metal corner piece so when you put the board back in the tips of the speaker contact the corner plates so the ear speaker will work.
이 답변이 도움이 되었나요?
점수 0
댓글 12개:
Ohh well originally putting it in I had no sound so tried it the other way then left it lol
의 공유
@kuro24592 updated my answer. How did you do that to the board?
의 공유
One of the screws needed to get the board out would not come out as it was threaded but before that i had the same issues
의 공유
@kuro24592 I take it you are testing it with the back screwed on?
의 공유
Yeah I have.
의 공유
댓글 7개 더보기
댓글 달기
الكمره لاتعمل القطه في الماه
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Calling sound problem and back camera blur
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Speaker not working
이 답변이 도움이 되었나요?
점수 0
댓글 달기
camra not wrking
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kuro 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 23
전체 시간: 1,024
