주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
10.1형 Galaxy Tab 태블릿의 세 번째 모델입니다.
LCD screen Ribbon Connector
Hi,
So i have a random question. I had a broken samsung tab 3 and iv taken it apart for a project. I wanted to know is there a way to change the Ribbon Connector to a 40pin? Or is there away of taking the gray tap (not sure whats its called) to put a 40pin ribben cable to it and complete void the LCD board.
Update (06/23/23)
이미지
Hi sorry about that.
Im wating to reuse it for a rasberry pi by installing a Display Monitor Driver Board
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
@learning201 the board we are looking at is the LCD driver board? Connected to your display panel? What is the exact model number for your tablet (GT-P5200?)
By using the display connector schematic, could you not determine which pin does what and move on from there.
의
댓글 달기
답변 1개
선택된 해법
if you add photos and the reason why you want to change to 40 pin then it will give people a better understanding of what you are trying to do
Update 06/23/23
@learning201 you would need to find out what each pin is for, some will be ground, others could be for single rails or you could have 2-3 pins connected to 1 rail
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Learning201 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 12
전체 시간: 405
