주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
갤럭시 A14는 삼성이 2023년 1월에 갤럭시 A13의 후속으로 출시한 저가형 슬레이트 안드로이드 스마트폰입니다. 모델 번호 SM-A145(그 뒤에 버전/이동 통신사별 문자)로 식별할 수 있습니다.
My phone has stack when I open WiFi
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
If your Samsung Galaxy A14 freezes or becomes unresponsive when you try to open Wi-Fi, here are some steps you can follow to resolve the issue
1. Restart Your Phone
  • How to do it: Hold the power button and tap "Restart."
  • This can help clear any temporary glitches.
2. Check for Software Updates
  • Steps:
    1. Go to SettingsSoftware update.
    2. Tap Download and Install.
  • Keeping your phone updated can resolve bugs.
3. Clear Cache for Wi-Fi
  • Steps:
    1. Go to SettingsApps.
    2. Tap the three-dot menu (top-right) → Show system apps.
    3. Search for Wi-Fi Direct or Wi-Fi settings.
    4. Select the app and tap Clear cache.
4. Reset Network Settings
  • Steps:
    1. Go to SettingsGeneral management.
    2. Select ResetReset network settings.
    3. Confirm the action.
  • Note: You’ll need to reconnect to Wi-Fi networks afterward.
5. Safe Mode
  • Boot your phone into Safe Mode to check if a third-party app is causing the issue:
    1. Turn off your phone.
    2. Turn it back on and press the Volume Down button until the home screen appears.
    3. Check if the issue persists.
    4. If the problem goes away, uninstall recently installed apps.
6. Free Up Storage
  • Since your device has limited storage left, it might cause performance issues.
  • Steps:
    1. Go to SettingsDevice careStorage.
    2. Delete unnecessary files or apps.
7. Factory Reset
  • If none of the above steps work, a factory reset might help:
    1. Go to SettingsGeneral managementReset.
    2. Select Factory data reset and follow the instructions.
  • Warning: Back up your data before proceeding.
If the issue persists after these steps, it might be a hardware issue, and you should consider visiting a Samsung service center.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It has been seven days since my phone started doing this
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Amiin Asker 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 254
