주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Bajaj Discover는 Bajaj Auto에서 생산하는 오토바이 브랜드입니다. 현재 Discover 100 DTS-Si, Discover 125 DTS-i, Discover 125ST, Discover 150 DTS-i 등 4가지 모델이 있습니다.
Start problem Bettry full charge Handle problem Kick problem
  • Start problem
  • Bettry full charge
  • Handle problem
  • Kick problem
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 7
댓글 4개
Start problem repairing
의
@sameertagala @vaibhavtaliyan we really need more history than just 3 words. If you are seriously wanting some help, you need to be more descriptive. At minimum we need to know what Bajaj model your bike is. Complete model number please. Then we need to know what the actual starting problem is. Then you need to tell us what you have already tried to fix this. Give it a try. You'll see that people will actually work to find a solution for you. We just have to know what the problem is.
의
Excilater not work bike cut out always
의
@parmmehmi what year, make and model? what have you checked? Since it cuts out, it could be related to your carburetor, the ignition or the fuel supply.
의
댓글 달기
답변 4개
가장 유용한 답변
Start problem solve for bike pulsar
이 답변이 도움이 되었나요?
점수 2
댓글 달기
If you are facing starting problem in pulsar So there is chance of problem in CDI coil, spark plug , spark plug cap, petrol Over flow and engine head.
Before you spend any money first try on petrol Over flow, you just do off petrol cock when you park your bike and when you go back on bike then on this cock.
If you will not get result then check spark , plug and current and do work on CDI.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Are you getting a spark from your plug when you put it against cylinder head, have you tried putting 5 ml petrol into cylinder head
이 답변이 도움이 되었나요?
점수 0
댓글 달기
{Bike's Solution}
1: Bike ka pulk saaf kare pahle
2:Air filter ko saaf kare
3: air mixture 🔩 ko set kare
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sameer Tagala 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 35
전체 시간: 2,685
