change battery which keeps date current
How do I find and change this little battery?
좋은 질문입니까?
좋은 질문입니까?
If you look at the repair guide on iFixit for removing the logic board Here: iMac G3 모델 M4984 로직 보드 교체
the battery is on the top of the logic board once you remove the assembly, there might be a black cover over it, but it uses a 3.6V 1/2 AA ( Lithium ) you ca buy them at radioshack (And pay an arm and a leg), or online where they are much cheaper
이 답변이 도움이 되었나요?
You can see the battery in step 8. The only twiddly bit is making sure of your alignment when reassembling so your optical drive works properly. You should be fine. Ralph
지난 24시간: 0
지난 7일: 12
지난 30일: 20
전체 시간: 5,064
