주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kenmore Elite HE3는 Kenmore에서 제조한 7.2 입방피트 용량의 전기 건조기입니다.
Dryer stops and f22 code
There is an F22 code and the dryer has stopped
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
@johnwhite72731 what is the exact model number for your dryer?
댓글 달기
답변 1개
가장 유용한 답변
The F22 is a door lock failure. Depending on your exact model number, you will need a specific part number to replace the door lock. It's a simple fix, about 5-15 minutes.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Disregard the other answer, F22 door lock failure is for a WASHER not a dryer.
For a DRYER, the F22 is an issue at the Outlet Thermistor. If F22 (or F23) flashes in the display after the dryer has been running for a minute or so and then the dryer shuts off, the issue is F22/F33 = Outlet Thermistor Fail and I think is that it is not controlling the heat appropriately (unable to shutoff heating element I think). You can also test this by running air dry (i.e., without heat) and it will NOT shutoff and NOT give error F22.
Per the technician manual, Check wire connections at machine control electronics (board) and at the thermistor. If the connections are ok, check the thermistor (Replace it if it's faulty, should be 10 kOhms), and check the two red wires at the outlet thermistor with a multimeter set to read ohms, and check each wire to the ground and if either is >0 ohms, then replace the WIRE HARNESS.
Source technician manual for Kenmore HE3 DRYER with images here: Kenmore-Elite-HE3-Dryer-Tech-Sheet.pdf
댓글 달기
답변을 추가하세요
John White 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 21
전체 시간: 898
