주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
미국에서 Acura 브랜드로 판매된 JDM 및 유럽형 Honda Accord 모델 CL9.
2015 Acura TLX need code
2015 Acura TLX 4 door sedan was running fine, driving normal running errands but went and parked for awhile but when it was time to leave it wouldnt start. Everything was locked up and it said a code is needed. Idk about a code. Please, I am afraid to drive it, I am afraid it will lock up while driving. Help
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Former Honda owner here!
You might see the navigation system say something like this. Of course, there are 2 ways to fix this. The first is you can simply press and hold the (Power) button for two seconds; the system should reactivate.
이미지
Now worst case that doesn't work you can get the code from accura instantly by going here: https://dev.radio-navicode.acura.com/
To get the S/N from the radio, you just press "Settings" "Info" and "back" for 3 seconds, and with the knob, scroll to detail information and setting. Then go to Unit Check and then ECU info. You can follow this video here
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Linda Kalakau 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 8
지난 30일: 39
전체 시간: 489
