주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년 10월에 출시된 모델이며, 모델 번호 CQ58-bf9WM, 1.0GHz AMD 듀얼 코어 프로세서 C-60으로 식별할 수 있습니다.
How to reset password
So i’ve found a old laptop deep in my storage room and i’m sure it’s full of old photos i’d like to get off so before i pay someone to get it off id like to try to do it my self. it’s a old laptop i think it’s running windows 8 i saw post on how to open the aso (advanced startup options) and tried goin to command prompt option and it makes me enter a password for my account. looking to reset it without loosing all of my pictures though. thanks!
Update (07/18/23)
also when i try to type in a password in the login screen it says “your pc is offline. please sign in with the last password used on this pc.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
Take out the drive, and connect it to a different computer. The process of removing the drive depends on what specific model the laptop is, but generally you remove the bottom, take the drive cover off, and then unplug the drive (there are usually a couple of screws holding the drive down, but they’re easy to remove). Most drives from the last 20 years connect with either SAS or SATA. You can buy a cheap USB to SAS (or USB to SATA) adapter cable on Amazon. Plug one end into the drive, and the other end into a USB port. The drive will show up in file explorer, and you can copy and paste all your videos and pictures to a different device. After that, you can put the drive back in the laptop, and then reset Windows.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
@oldturkey03 Thanks for the advice!
의 공유
@shingle Great Answer!
의 공유
댓글 달기
답변을 추가하세요
lolguy1100 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 22
전체 시간: 556
