How to fix indicators not working
Indicators not working including harzards
좋은 질문입니까?
For both the turn signals and the hazard light not to work it could be a problem with the hazard switch or the flasher unit.
If you can't hear the flasher unit clicking when the turn signal lever or the hazard switch is operated, more than likely the flasher unit is the problem.
Here's a video that may help to show where it's located. I realize it says for a 2001 Sentra but this is the USA model name for a Sunny.
Here's the electrical wiring diagram for the turn/hazard signals that may help if it isn't the relay or the switch
(click on image)
이 답변이 도움이 되었나요?
Having been working on cars for half a century now, my old school experience tells me that the first thing to try here is the flasher unit marked M42 on the wiring diagram. That's the part that used to go out all the time, although on modern cars you rarely have to replace them any more. All the same, I'd bet on that first before the hazard switch.
Check for any loose connections or maybe its the problem with the bulb..try changing it
이 답변이 도움이 되었나요?
지난 24시간: 6
지난 7일: 37
지난 30일: 59
전체 시간: 734
댓글 2개
Hi @dandaniel29708,
What is the year model of the vehicle?
jayeff 의
2001
B15 nissan sunny
Dan Daniel 의
