주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fitbit Charge 5는 2021년 8월 25일에 출시된 피트니스 트래커입니다. 심전도(ECG) 센서, 손목의 땀을 측정하는 피부 전기 활동(EDA) 센서, 그리고 컬러 AMOLED 디스플레이가 추가되었습니다.
Is this a broken screen?
My Fitbit charge 5 screen won’t turn on. It turns on for a second and then fades back out. I tried the charger reset twice and it didn’t fix the problem. It vibrates when I tap it (sometimes) but it isn’t tracking anything according to my app.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Open your Fitbit app on your phone and see if the watch is connected. Or put it on charge then try it. If it connects take it off charge and see if it disconnects. If it does then as mentioned earlier you probably need a new battery. I have three Fitbit’s, all without a screen and I can test to see if they are on or off this way.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
Hi Abbie,
I don't know enough about your Fitbit to diagnose the problem you're seeing, but I can be fairly confident that it's not a screen problem; the behavior you're describing isn't consistent with either a bad touch screen or a bad display.
I'd lean toward it being a battery issue myself, but you'll probably want someone with a bit more intimate knowledge to check in with first.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Abbie McCauley 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 31
전체 시간: 2,172
