주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Onkyo TX-800은 1989년에 출시되어 2002년에 단종된 솔리드 스테이트 리시버입니다.
Why won't the left main speakers work?
I bought new speakers for my Onkyo receiver. I've connected the speakers with speaker wire to the main speakers outlet in the back of the receiver. Only the right side speakers produce sound. To check if I'd made a faulty connection, I then switched each around, and the same result occurred; the right side works, the left does not.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 3개
Laura, don't mean to insult you, but did you check the balance settings? Any difference?
의
Yes, I'd already looked into the balance settings.
Looking at the manual, t appears as though this is over-my-head. I will look into finding professional repair. Thank you!
의
Laura, thank you for accepting my answer. Best of luck to you....:)
의
댓글 달기
답변 1개
선택된 해법
if you have no difference on your balance settings, I would go ahead and take a look at the AN7470 Stereo decoder as well as the IC NJM45580-x. Of course you also should look for any burned out components on the logic board. Download the service manual for your Onkyo from here. It does have the circuit diagram as well as a parts list that will help you with it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Laura 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 20
전체 시간: 4,085
