주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell OptiPlex 360은 실용적인 기능을 갖춘 비용 효율적인 데스크톱 솔루션으로, 비즈니스에 필수적인 가치를 제공하는 데 중점을 둡니다.
Motherboard is not working
Motherboard is not working properly
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 5개
What part of the motherboard is not working? Can you give more details of the issue?
@kumailkazmi you really need to give us lots more information if you expect some help with this. At minimum we need to know why you think that your motherboard is not working properly. What make and model motherboard? What does or does it not do? What have you checked and what have you tried to fix this?
The fan did not spin
=== Update (09/17/23) ===
@amiribnmohammed if you need help with this you want to give us all the information. The fan did not spin is just to vague. What does your computer do? It overheats? Did it overheat because the fan didn't spin? Did you replace the fan? What did you check?
The only logical answer based on your question would be : Replace the fan.
Yes my mother board is not working
=== Update (10/01/23) ===
Yes mother board not working
댓글 달기
답변 1개
가장 유용한 답변
might be a power issue with the powerbutton on the case, if so. short the pins using a screwdriver or somethign else
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Kumail Kazmi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 498
