주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Acer TravelMate P255-MG 수리 안내서, 매뉴얼 및 문제해결 도움말. TravelMate P255-MG 노트북을 직접 수리하는 데 필요한 모든 정보가 여기 있습니다.
tochpad don't work
hardware tochpad don't work
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@pyaar you are not giving us a lot of information. You are not telling us if this just stated or if anything happened. you are also not telling us what you have checked and what you have tried to fix it.
The very first thing you want to check is to make sure that your touchpad is enabled. You should get this done via your keyboard. FN + F6 or FN+F7 will enable/disable your touchpad.
If that does not work, update and reinstall your driver. Check on the Acer website for the drivers
After that, you will have to open your computer and check the physical connection. Also, if you have a battery that is old and starting to swell, it will impede the function of the touchpad. So, take a look at that as well.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
አብርሃም ፒያንኪ (Pyaar) 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 20
전체 시간: 340
