주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2011년에 HP가 개발한 webOS 플랫폼 기반의 태블릿입니다. 9.7인치 디스플레이를 자랑하며, 16GB 또는 32GB 모델로 출시되었습니다. 수리는 간단한 편이지만, 시간과 끈기가 필요합니다.
Touchpad will not power on.
We bought a Touchpad at one of the firesales online; thus no warranty. Had it 3 weeks and it appeared to be stuck on the last page viewed (on a slant). We could not exit or power off, until we simultaneously pressed the volume up and power button at the same time. Now it will not power on. Have tried numerous cords and nothing. Help
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 8
댓글 달기
답변 8개
가장 유용한 답변
try this reset mode- hold down power button and press the home key button on the front of the touchpad 15 times in a row. then release power.
이 답변이 도움이 되었나요?
점수 7
댓글 1개:
Thanks, you saved me. My Touch Pad was stuck in retart...
의
댓글 달기
Battery is the most likely reason. It sometimes (software bug?) lets the battery discharge below the safety levels for LiPo cells. This is your case since you let it "stuck" on a page until the voltage fell below safety levels. If the circuits detect that low level voltage, it does not even charge because it is said to be dangerous to charge a deep-discharged LiPo (fire danger).
Your best shot is to buy a replacement battery and have it replaced or do it yourself.
So, try to replace the battery. I did so and it worked...
BTW, I also tried reviving the battery by slow charging it with a RC LiPo charger but it was too deeply discharged!
이 답변이 도움이 되었나요?
점수 5
댓글 2개:
how long do we wait
의
From where i got the new battery ???
의
댓글 달기
When TouchPad will not respond to the power button and you know for a fact that the battery has a charge and or is plugged in to charger. Hold the power button along with the Home button and hold them together for 10-15 seconds. TouchPad will go in to a hard reset and will boot with the HP logo. You can then reboot to boot on to android if needed.
Hope this helps.. jcs
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I think your best shot is to change the battery... It's not VERY hard to do but you have to be carefull in order not ot kill the device. Maybe you can have an expert do it for you.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
ok try pressing the big hp logo the volume down and the power button for 30s
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Cuado estaba desconectando el microfono, estaba levantado el clip blanco que sugeta la lamina, se deprendi y la perdi. Como puedo solucionar el problema para reconectar el micrófono.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Thank you to Kathy, Vector Vector…and everyone for the postings…. Very helpful, finally my old HP Touchpad alive again. Thank you to all of you again!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
How do I do while manufacture reset I’ll touch base
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
How do I do a manufactured reset all of the model number 014328003945259
의
댓글 달기
답변을 추가하세요
Kathy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 11
지난 30일: 43
전체 시간: 41,203
