주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2017년 5월 23일에 출시된 Dell UltraSharp 라인업의 HDR 지원 4K 모니터입니다.
Gray blobs on screen
Just bought this monitor used. Works great, but there are gray blobs visible when viewing brighter colors.
The blobs have defined edges. Perhaps water damage or pressure damage.
Any thoughts would be helpful. I will repair myself, if that is possible.
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Those definitely look like water spots to me. @oldturkey03 has a lot more experience with this than me, but my guess, assuming the spots aren't on the surface, is that there's a good chance you could disassemble the screen and clean the individual layers of polarizer, LCD and backlight. You just have to be very careful to reassemble everything in the exact same sequence and orientation you took it apart in, and of course whatever you do, don't apply too much pressure to the LCD; if you crack it, it's pretty much game over.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
I wasn't expecting such a quick response!
Thank you very much for your insight. I will try it out if I decide to keep it. I now know that if I do keep it, there is a good possibility of repair.
Have a great one!
의
@bbcski I concur with @dadibrkeit. Looks like stains on the diffuser. You can fix it by disassembling the complete panel and cleaning the sheets. 2 things to be careful of. Do not bend the panel, secure the driver boards that are attached to the panel, with some painters tape. Next is to mark the order and the direction of how the sheets are inside the panel. They have to be re-assembled in the same order and direction.
의
댓글 달기
답변을 추가하세요
BenC 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 22
전체 시간: 477
