주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple의 2020년 주력 iPhone은 10월 23일에 출시되었으며, 6.1인치 OLED 디스플레이, 듀얼 12MP 카메라 시스템을 탑재했고 5가지 색상으로 제공됩니다. iPhone 11의 후속 모델입니다.
My earpiece speaker not working
My phone's small speaker for calls is not working, it just stopped working. I need to put a call on loudspeaker to hear my calls.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
You will, of course, want to try all the software solutions you can think of, as well as cleaning the speaker grille with a soft brush, maybe some compressed air, and some 90% or higher isopropyl alcohol.
If all that fails, the fault may well be with the speaker itself. On your phone it's part of an assembly called the Earpiece Speaker Assembly. The bad news here is that replacing that assembly will kill your Face ID and the only way to get it back is to pay Apple for a full screen replacement.
However, a guy on YouTube found that the speaker is only secured by two small solder points and replacing it by itself does not affect Face ID. I wrote a guide for that procedure on the iPhone X, but it is very much applicable to your iPhone 12. Start with your Earpiece Speaker and Front Sensor Assembly guide and follow it through Step 28.
iPhone 12 Earpiece Speaker and Front Sensor Assembly Replacement - iFixit Repair Guide
Once you get there, switch over to the iPhone X Earpiece Speaker replacement guide on Step 29. That will guide you through the two small solder points you need to unsolder to disconnect the old speaker and replace it with a new one.
iPhone X Earpiece Speaker Replacement Without Losing Face ID - iFixit Repair Guide
If you decide to do this, take pictures of everything after Step 28 and use my guide as an example of how to create your own guide so people who follow after you have a guide to go by.
iPhone 12 이어피스 스피커와 전면 센서 어셈블리 이미지
안내서
iPhone 12 이어피스 스피커와 전면 센서 어셈블리 교체
난이도:
조정
1 - 2 hours
iPhone X 이어 피스 스피커 이미지
안내서
Face ID를 유지한 채 iPhone X 이어 피스 스피커 교체하기
난이도:
조정
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Try but a new earpiece and replace it the retest.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
fethy nduli 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 36
전체 시간: 487
