주요 콘텐츠로 건너뛰기
내장형 하드 드라이브에서 네트워크 연결 드라이브에 이르는 다양한 종류의 저장 공간 수리 안내서.
633 질문 전체 보기
Is it possible to find QNAP TS-409U replacement parts
Is it possible to find reasonable cost replacement parts for a 1U QNAP NAS device? A QNAP TS-409U, no device page for any QNAP stuff yet.
I could use a new power supply for this model I listed above and have not been able to find anything from regular searches. I will be calling around during normal hours tomorrow, but thought it could not hurt to ask and see if anyone had a online resource i am not aware of for a device like this. ( i would hope a power supply would not be terribly expensive, this is my fear and another reason i am asking) these types of devices are fairly expensive to purchase and of course replace if not repair is not possible.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Brian, sure looks like a proverbial needle in a haystack. Looks like the TS409-U uses a Channel Well Technology (CWT) PSM 200A-89. The QNAP part number is SP-5BAY-PSU. The only values I can find are:
Input:115-230V, 47-63 Hz, 3.0A
+5V 13A 65W max
+3.3V 17A 56W max
+12V 15A 180W max
-12V 0.3A 3.6W max
+5V 2A 10W max
Here are a few suppliers, depending on your region. Looks like it's popular in Europe (and expensive;) http://eng.estock.fr/basketadd.php?partn... Here is the one from Qnap http://shop.qnap.com/index.php?route=pro... The layout and a bit more data on the power supply from here http://www.cwt.com.tw/upfiles/layout0123... Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Fantastic, this is the kind of info i was hoping to find, sure beats buying another model, thank you.
Thanks for accepting my answer. Best of luck to you :)
댓글 달기
Hey
I'm looking to replace the PSU in my 409U as well.
I am currently running it off a standard ATX PC PSU.
any ATX 1U PSU of apropriate wattage will do.
I have ssen a few on e-bay which can be made to fit but I am yet to find one that will directly replace the 15cm model on the NAS.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Brian 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 7
전체 시간: 4,354
