XIAOMI Mi L32M6-EI TV는 Mi TV 4A 호라이즌 에디션(32인치)이라고도 불리며, 2020년에 출시된 HD 레디(1366 x 768) 스마트 안드로이드 LED TV입니다. 이 기기는 크롬캐스트와 구글 어시스턴트가 내장된 안드로이드 TV 운영 체제에서 실행됩니다.
To add to the above, we need a picture of the issue but if its really thin, maybe single pixel wide, lines that are (from what I've seen personally) usually green, red, or black - its likely that strip of pixels failing or physical damage. Which isn't often repairable without replacement of the LCD screen itself as far as I know, unfortunately.
@ratishulvekar post a picture of what your screen shows you, with your question. We need to see what you see 기존 질문에 이미지 추가하기
oldturkey03 의
Can't help diagnose without a picture though.
SparkWorx 의
I have the same horizontal line issue
Chandru Prakash 의
I am facing horizontal line issue can it be repaired or I have to change the panel.
Upasana Dutta 의
@upasanadutta post a picture of what your screen shows you, with your question. We need to see what you see 기존 질문에 이미지 추가하기
oldturkey03 의
댓글 2개 더보기
