My PC is not starting.
My PC's SMPS (power supply) is working properly and cleaned RAM then also my PC is not starting. Green light is stable in PC, monitor is also in good condition.
좋은 질문입니까?
좋은 질문입니까?
1 or more of your RAM sticks might be dead
Try this trick: turn on your computer with 1 of your RAM sticks, if your display turns on that RAM stick works, if it doesn’t that RAM stick is dead repeat until all of your RAM sticks have been tested.
이 답변이 도움이 되었나요?
Testa o HD e depois o processador se tiver outros componentes para teste.
Retire a bateria da placa mãe e aguarde de 2 a 3 minutos e recoloque na placa, isso esse da as configurações da bios.
이 답변이 도움이 되었나요?
amps not working power is not supply
smps not working power is not supply
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 682
