주요 콘텐츠로 건너뛰기
2018년 10월 26일 출시. Models A1984, A2105, A2106, A2108. GSM 또는 CDMA / eSIM, nano-SIM 또는 dual-SIM / 64, 128, 또는 256GB / 검정색, 흰색, 파란색, 노란색, 산호색, 또는 빨간색. ("iPhone 10 R"로 발음합니다.)
470 질문 전체 보기
forgot to keep my XR out of water, iPhone IS NOT AVAILABLE
i went to beach yesterday and i forgot to keep my XR out of water, after i discovered that my phone is with me i took it out to check it and it display IPHONE IS NOT AVAILABLE then it went off and i dried it out then it request for charging and i charge it for like 12 hours now it just keep showing Apple Logo and went off back. PLEASE HELP ME OUT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @muhammad37946
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit iPhone XR guides that will help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Muhammad 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 18
