주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2002년에 출시되었습니다.
Is my iMac dead?
iMac G4 17 800 MHzEMC1936
Hi I've got an iMac G4 17" it's been unplugged for a year. I'm trying to get it running again but now it won't do a thing.
I've had the lead checked and that's ok, opened it up and reset the PMU, replaced the battery (and reset the PMU again), but each time no joy and absolutely no response.
Does this mean the power unit needs replacing or the logic board ? Or could it be something much simpler, there's never been any hint of anything wrong with the computer before.
Considering binning it once I've taken out the hard drive.
Thanks.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
My g4 did the same thing just had it fixed and it was the power supply unit inside I did reset and replaced battery and nothing so I'm betting it's the same problem
의
댓글 달기
답변 1개
선택된 해법
Since you've opened it up check that all connections securely and correctly reconnected to the logic board. If a connection is bad pressing the start button might do nothing.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
phillip naylor 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 16
전체 시간: 1,835
