주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼 코어 Intel Core i7 프로세서.
Start up issues- flickering screen.
My computer just started flickering between the passcode screen and the start up screen when i open it from sleeping (closed). I can force it to shut down by holding the power button and then restart it, it boots up fine.
I haven’t been able to find this particular issue in searches and am hoping someone here might know what is happening and what i need to do to repair.
I am now only able to use it when connected to the power-cord- i gave s new battery coming to replace the current one. (Not sure if this could be related to the flickering)
Thanks in advance for all help.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
선택된 해법
I'm not sure if the poor condition battery is related to the flickering issue. If it only occurs after waking from sleep if might have to do with your sleep/wake settings. It would be a good idea to try restoring the default settings. You could also try an SMC reset or NVRAM reset. As a last resort you could try reinstalling the OS. Good luck!
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Given the systems age it’s likely the battery is just too old. Install this gem of an App to check your batteries health CoconutBattery
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
I actually already installed that after looking through other forum questions. This battery is showing 0 health.
의 공유
@daphnevega - Bingo! You need a new battery.
The flickering is do to the backlight doesn't have power stabilization logic so as the MagSafe contacts break contact due to dirt the system will flicker when dependent on AC power. Also note some actions will require more power than the MagSafe charger can offer so even with a clean MagSafe the power demand of the CPU can disrupt the backlight power needs.
의 공유
Thanks, Dan- I am glad to get some consensus that it is the battery- that I am already prepared to replace. I love this laptop and am hoping for a few more good years out of it. :)
의 공유
댓글 달기
답변을 추가하세요
Daphne Vega 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 8
지난 30일: 29
전체 시간: 864
