주요 콘텐츠로 건너뛰기
OnePlus released its first smartwatch in April 2021. The OnePlus Watch comes with Wi-Fi, Bluetooth, 1 GB of RAM, 4 GB of storage, speakers, and GPS.
cold battery will not charge where do you buy battery?
will not charge says cold battery
Update (09/25/23)
where do you buy battery for plus one watch
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
Could be a bad temperature sensor.
Li-ion batteries shouldn't be charged below 40 F ( ~ 5 C) so there is a sensor to check for this.
If you warm it up, can you make the message go away?
Not work my wacth
A comedian. Very funny. My wacth (sic)
댓글 달기
답변 2개
가장 유용한 답변
@frankdidente could be a bad battery. The battery has a temperature sensor, and a failed battery control board can give you that error. Start by replacing the battery.
Check this OnePlus Watch Teardown and see if this is something you would tackle.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I replaced the battery and it worked using battery from:
I just found this on AliExpress:
C$37.99 | new original for OnePlus XE202 Watch battery
https://a.aliexpress.com/_mOAz1z9
The wearable now works!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
FRANK DIDENTE 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 358
