주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xiaomi Redmi Note 3 스마트폰은 2016년 3월에 출시되었습니다. 교체 불가능한 4,050mAh 배터리가 내장되어 있으며 최대 256GB까지 확장 가능한 저장 공간을 지원합니다.
Charging stopped in mi
  • Charging connctor not works
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Sanjay,
I'm taking you at your word that the micro USB port on your phone is somehow not working and needs to be replaced. That assumes you've checked the obvious things like trying a different charger and cord, along with cleaning out the charging port.
So, given you want to replace the port, you're in luck. On your phone it's on a separate circuit board from the motherboard and thus is cheap and easy to replace without needing any soldering skills. iFixit has a video guide showing how to unsolder and replace the port, but that's far more work than is necessary to fix your phone. Use this guide from the Spanish site Nadie Me Llama Gallina to replace your auxiliary board.
Manuales / Xiaomi Redmi Note 3 / Auxiliary plate
The part you can get online on several places; I usually start with Amazon, eBay and AliExpress.
Just so you know, with charging problems there could be other causes beside the port; the battery itself could be bad or the charging circuitry on the motherboard might not be working, but the charging port is a good place to start.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Sanjay99 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 14
전체 시간: 355
