@afyasyedshah Rice does not work. It does absolutely nothing to help you with this repair. All it does is waste time and waste food. Check here https://www.ifixit.com/News/30047/rice-i... for more on this.
For now, you must stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
The very first step I would take is to disassemble your phone. Since iFixit doe not yet have a guide for this phone, use something like thios videoto help you disassemble your phone. You will need to get the mainboard as well as the charging board out. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You will have to remove all the EMI shields from the circuit boards. If you do not remove the shields, you are not cleaning the board. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more.
For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your iPad as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. You do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would of course be best to get it professionally cleaned with an ultrasonic cleaner. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that, reassemble your phone and re-evaluate.
Until it is cleaned, everything will only be a guess. It is possible that you have a bad LCD and replacing the display assembly may fix it. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
ํด๋น ๋ต๋ณ์ ๋์์ด ๋์์ต๋๊น?
ํฌํํจ
์คํ ์ทจ์
์ทจ์
์ด ํ ๋ก ๊ธ์ ์คํฌ๋กคํ์ฌ ๋๊ธ์ ๋ฌ ์ ์ ํ ์์น๋ฅผ ์ฐพ์ผ์ธ์. ๊ทธ๋ฐ ๋ค์ "์ด ๊ฒ์๊ธ์ ๋๊ธ ๋ฌ๊ธฐ"๋ฅผ ํด๋ฆญํ์ฌ ๋๊ธ์ ์ด๋ํ์ธ์.
