주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Acer Aspire 3 A315는 Acer에서 출시한 수리 가능한 노트북입니다.
My keyboard is not working
My keyboard is not working except the power button do i need to reset this laptop ?thank you.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 1개:
Sherwin, have you tried plugging in a USB keyboard? That may get you by while you try to fix it.
의
댓글 달기
답변 5개
Hello @sherwinundug,
First of all connect an external keyboard with usb and then try to download manually your drivers or delete device from device manager and then restart your laptop. It should be ok. If problem remains, then you should check if the connector is ok and then replace it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hey @sherwinundug , i had the same issue twice!
The keyboard is a entire piece with the superior frame, so for fix, you need a replace this piece.
The piece Number in my case the Aspire 3 A315/A515 is AP28Z000300-HA25.
Or you can Jump the board and add a Switch for boot up.
이미지
Pins 1 and 2
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Well I will suggest you to update the keyboard driver some time any outdated keyboard driver can also cause this kind of issue as well.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
@gtip a update don't work, i tried!
Is a common issue in this model. My laptop, i replace this entire frame twice, and works like 2 years and fail again, a believe is a programmed obsolecense
의
Hola quetal la verdad es que Ami me pasaba mucho cuando lo tuve, no sé si es lo mismo que te sucede pero por lo que as dicho es igual a lo que me pasaba , después de una larga investigación en esos tiempos me di cuenta que era por una combinación de teclas.
의
댓글 달기
You don’t need to reset your laptop immediately. If your keyboard isn’t working. Try to reslove it first, try some methods like use external keyboard, update keyboard driver etc.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Try restarting first. If the keyboard still doesn’t work, check driver updates or reconnect the internal keyboard cable before resetting.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sherwin undug 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 25
지난 30일: 112
전체 시간: 2,532
