주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
A1708/EMC 3164 — 2017년 6월 출시, 이 보급형 MacBook Pro는 기존의 펑션 키를 그대로 유지합니다(OLED 터치 바와 대조적).
New battery not working
Hi,
Added a new battery today and not Good so far.
The device only powers on with power cable connected.
It won't turn on straight away when I press the power button, if takes a minute or so then comes on.
When I originally put the trackpad back and notice a spark, would this device be shot here even of its turning on at the moment?
I've also just ordered another BMC flex cable.
Help appreciated
이미지
이미지
이미지
Here you go on images
Update (09/27/23)
UPDATE - Just noticed I didn't unclip the BMU when removing.
Also, the connector to the battery board came out when installing.
1. Could these be broken if yanked out not pulled out with the clip open?
2. Does a new cable solve this? If yes I'll need to wait a few days till it arrives to conclude on this!
3. My god Apple complicate things on mainboards lol. You need to be Tom Thumb
Update (09/28/23)
Update - just tried multimeter on new battery and got readings so suggests it isn't a dud battery?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Can you install this gem of an App CoconutBattery then take a snapshot of the Apps main window and post it here for us to see.
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
No I've tried this and says it's now not supported on mine.
In system report I can't see the battery so can't be installed.
@danmacman - I guess we will need a few clear pics of the connector and the cable. It sounds like either one is damaged.
@danmacman - what hard to see in your second image it looks like the cable was over flexed cracking the traces! So take a magnifier and double check, hopefully a new cable will correct that.
So I have a battery working.
# New cable arrived and worked straight away
# Then stopped working when I put the cover back on
# Appeared the connecter clip for the the cable on the battery PCB was not clipping fully down, maybe this battery manufacture that was poor in the first place as it had some yellow film on it to hold it down.
# Reapplying the same tape down with some electrical insulation as now held the clip down
Something also clicked while waiting for the cable and that was that the first time I put the cable in on the original try the Low battery warning came up so this must had worked originally and I'd be surprised that other two cables are even broken tbh.
Thanks for the help. Why Apple put a clip this small in along with it being backwards is beyond me, maybe it's just because they can?
댓글 달기
답변을 추가하세요
Daniel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 13
전체 시간: 314
