주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
upgrade to more modern logic board a1278
hi
I bought a MacBook Pro a1278 primarily as a DVD player but am a writer and love the case, keyboard etc
can you get a more modern logic board that would work with this chassis?
I have tried google without success!
thank you in advance
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
@trencesmith unfortunately you cannot. The issue is that Apple keeps on changing the layout of the logic boards. Connectors, cables, RAM , etc are all different and in different locations etc. The only close board that will fit is the Mid-2012. It needs some minor mod on the LVDS connector since it is a little to wide for this board MacBook Pro 13" Unibody (Mid 2012) 2.9 GHz Logic Board Cost, amount of work etc are all a factor on this. You really will only have minor performance improvement. So, you are kind of (mostly) stuck with what you got. Keep using and enjoying it for the purpose you bought it for, "primarily as a DVD player"
Replace a 2.9 GHz logic board (motherboard) compatible with the Mid 2012 MacBook Pro 13" Unibody laptop. Included Ports: FireWire 800, Thunderbolt (Mini DisplayPort), 1000BaseT Ethernet, 2 USB 3.0, Audio In/Audio Out, SD card slot. Fix processing issues like unexpected shutdowns, reboots, or water damage. 이미지
제품
$155.99
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
trence smith 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 4
전체 시간: 180
