주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
삼성 갤럭시 A10s는 삼성전자에서 개발한 안드로이드 스마트폰으로, 2019년 3월에 출시되었습니다.
My camera is not working
My camera app isn't open and my phone says camera isn't connected
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 3개
My phone camera is not working
의
Camera did not
connected problem
의
My samsung a10s the camera is not the
의
댓글 달기
답변 2개
가장 유용한 답변
Some time camera could not connected
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Camera still not working after all steps attempt.
의
댓글 달기
I’m sorry to hear that your camera app isn’t opening and your phone says camera isn’t connected. This could be due to various reasons, such as a faulty camera module, a corrupted camera app, or a software glitch. Here are some possible solutions that you can try:
  • You can reset the camera app by following these steps1:
    • Open Camera and select Settings.
    • Select Reset settings.
    • Tap Reset to reset the Camera app.
  • You can check for any updates for the camera app or your device’s software by following these steps2:
    • Open Settings and select Software update.
    • Tap Download and install to check for any updates.
    • If there are any updates available, follow the on-screen instructions to install them.
  • You can reboot your phone into Safe Mode and test the camera app by following these steps3:
    • Hold down the power button until the Power menu pops up.
    • Tap and hold the Power off button.
    • Tap “Safe mode.”
    • Test the Camera once it reboots in Safe mode.
    • If it’s working fine, a third-party app may be causing the problem. You can uninstall any suspicious apps or disable them in Settings > Apps.
  • You can watch some videos that show how to fix the camera not connected problem on Samsung A10s. For example, you can check out these videos: Samsung A10s Camera Not Working Problem Solved . They demonstrate how to use a multimeter and a soldering iron to repair the camera module and restore the connection.
I hope this helps you fix your Samsung Galaxy A10 camera not connected problem. If you have any other questions, please feel free to ask me. 😊
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Amar Mohammed 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 6
지난 30일: 18
전체 시간: 1,274
