주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Elitebook 745 G6를 원활하게 관리할 수 있도록 포괄적인 수리 안내서, 문제해결 솔루션 및 유용한 정보를 여기서 확인하세요.
Laptop is shutdown problem
the laptop shutdown while the charge is full or 95%
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I’m sorry to hear that your HP Elitebook 745 G6 laptop is shutting down unexpectedly. There could be several possible causes for this issue, such as hardware failure, software corruption, overheating, or power settings. Here are some steps you can try to troubleshoot and fix the problem:
  • Run a system test using the HP PC Hardware Diagnostics for Windows app. This app can check the health of your laptop’s components and identify any potential issues. If a component fails a test, write down the failure ID (24-digit code) and contact HP Customer Support1.
  • Unplug the AC power from the laptop. Press and hold the power button for more than 12 seconds. Release the power button (after at least 12 seconds). Re-connect the AC power to the laptop. This will perform a hard reset and clear any static charge that might be causing the issue.
  • Check the power settings of your laptop and make sure they are not set to hibernate or sleep instead of shutdown. You can do this by going to Settings > System > Power & sleep > Additional power settings > Choose what the power button does. You may also want to disable the fast startup option, which can sometimes interfere with the proper shutdown process2.
  • Update your laptop’s BIOS, drivers, and Windows to the latest versions. This can help resolve any compatibility or performance issues that might be causing the shutdown problem. You can use the HP Support Assistant app or visit the HP website to download and install the updates.
  • Scan and repair any corrupted system files using the System File Checker (SFC) utility. This utility can fix any errors or damage in your Windows system files that might be preventing your laptop from shutting down properly. To run this utility, open Command Prompt as an administrator and type “sfc /scannow” (without quotes). This process might take some time, and once it’s complete, restart your laptop and check if the issue persists3.
  • Clean the vents and fans of your laptop to remove any dust or debris that might be blocking the airflow and causing overheating. Overheating can cause your laptop to shut down abruptly to prevent damage to the hardware. You can use a soft brush or a can of compressed air to gently clean the vents and fans. You may also want to use a cooling pad or elevate your laptop to improve ventilation.
I hope these steps help you resolve the issue. If none of them work, you may need to contact HP Customer Support or a local service center for further assistance. Have a nice day! 😊
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Abenezer Bekele 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 33
전체 시간: 819
