주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Precision 5550 워크스테이션은 Dell에서 제조한 노트북입니다. 이 페이지는 Dell Precision 5550과 관련된 수리 및 서비스 정보를 담고 있습니다.
Battery Replacement Not Accepted
Hello. I just received a replacement battery from iFixit, and my laptop won’t boot into windows with it installed. Placed the old battery back in, and everything works just fine.
Does Dell lock their BIOS down if non-Dell parts are installed? And is there a trick to bypassing this?
Battery is the Dell 69KF2
Edit: The picture is the error I receive when plugged in
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 5개
With the new battery installed, does it make it to the BIOS or does it completely brick up?
의 공유
It makes it to the BIOS, but it warns me that the battery isn’t a Dell certified battery.
의 공유
So it comes up and has a warning that your battery isn't genuine and it won't let you past it?
의 공유
Yes. That’s exactly it.
의 공유
Yep, I believe dell has some chip that does a virtual handshake with the battery to make sure it's oem.
Edit: Sorry i can't be of much be of much help, dell is kinda funny like that and I actually just went through this same thing but I ordered from parts people to make sure it was oem.
의 공유
댓글 달기
답변 2개
가장 유용한 답변
The issue here is Dell uses a custom TI battery gauge which also does a challenge/response code with the BIOS; if the response is not emulated (legal issues for sites like iFixit to knowingly sell) or a Dell BMS is reset and reused (legal since it's not cloned), it will reject the pack. This started with the E series due to the D series 2005 Sony recall. The issue is now by the time it's cracked, the laptops are so decrepit it doesn't matter to Dell, and the machines are mostly retired. Maybe RtR will fix this on future machines (potentially some older models), but Dell has begun to sell batteries on their site for "internal" laptops :-). This is where you can get the "right" battery now. You can get it at a slight discount from PartsPeople as well.
While Dell doesn't vendor lock things like SSDs and RAM (even screens), the battery IS locked down. That's why you can get a garbage spec machine from them with a good CPU at a healthy discount as a factory refurb and then buy the parts you really wanted like a 1TB SSD.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Dell doesen't usually do this, so it can be a problem with the battery. Try cleaning the battery.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Yeah, I think Dell is usually pretty open about repair and parts.
의 공유
I thought so too, but the photo from the BIOS is the error I receive when I turn the machine on
의 공유
댓글 달기
답변을 추가하세요
Logan Endicott 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 102
전체 시간: 2,076
