주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Grand Neo는 2014년 2월에 출시되었습니다. 5.01인치 디스플레이와 듀얼 SIM 변형 모델을 갖춘 중급형 스마트폰입니다. GT-I9060I 모델은 Samsung Galaxy Grand Neo Plus로 알려져 있습니다.
How to break pin lock
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Pattern removal
의
댓글 달기
답변 1개
선택된 해법
If you forgot the pin code you can do a Hard reset via the recovery menu options which will wipe the phone and remove the pin lock however you will need to login to your Google account that was previously used on the phone to continue to setup your phone after the reset is done.
To do a hard reset via the recovery menu please use the button combination as follows:
With the phone powered off, HOLD (Power + Vol ⬆️ + Home) buttons until you see the Samsung logo on the screen then release the buttons. The phone should now be in recovery Menu. From the recovery menu use the Vol+ & Vol- buttons to select the option you want and use the power button to select it.
  • Remember doing a hard reset of your phone will wipe all data on the phone and cannot be recovered. Make sure you have your data backed up prior to doing a hard reset. Doing this Will activate factory reset protection on the phone and you will need to login with the Google account previously used on the device to be able to continue set up on the phone so do not use this method unless you know the Google account that was previously used to sign in on the phone!
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
If you forget your previous Google account that was used to sign in on this phone
의
I have this problem
의
댓글 달기
답변을 추가하세요
Sikandar K Rataniya 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 35
전체 시간: 947
