주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2세대 Apple 실리콘(M2 칩)과 13.3인치 Retina 디스플레이가 탑재된 MacBook Pro 13" 모델을 위한 수리 안내서입니다. 모델 번호는 A2338입니다. MacBook Air M2와 함께 2022년 7월 15일 WWDC 2022에서 처음 공개되었습니다.
Screen Problem, blurred lines at bottom of screen.
Hello,
My Mac have developed some blurring at the bottom on the screen. It covers the entire width of the screen and is about 1/4" high.
I took it into Apple and they said it needed "screen controller" repair costing about $600.
Has anyone else had this issue and was able to perform a fix themselves.
Thanks
Andrew.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Sadly its out of warranty !!!!!!
댓글 달기
답변 2개
Ouch! Your system should still be under warranty!
Double check if it is, then go to anther Apple store or dealer as this should be a free repair!
Unless there is visible damage around the displays chin area I can’t see any reason to be denied.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
@andrewusherwood - If its just outside the window by a few weeks I would still press Apple, But you need to lean on them a bit. Be pleasant but firm, escalate it up the food chain, I'm sure you should be able to get this fixed for free!
댓글 달기
I have the same problem, just just happen just I made an upgrade to Sonoma, I a few weeks after. Now, I don't know if its is hardware problem, or is it an software/driver issue. How can I tell, and take appropriate. I reverted to the original OS that come with the laptop, but the issue still persist.
Hope some can help..
Thanks
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
@georgetuges - Plug in an external display, if the image is clean on it, it tells us your internal displays logic is damaged and you likely need a new display assembly.
댓글 달기
답변을 추가하세요
Andrew Usherwood 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 30
전체 시간: 1,010
