주요 콘텐츠로 건너뛰기
Repair and disassembly information for the Samsung Galaxy Buds Pro wireless earbuds.
26 질문 전체 보기
Buds Pro got washed in the washing machine, what to do now?
Happened yesterday and I kept them in rice for over a day now. The case is fine and the buds audio is good but the mics are screwed up, especially on the right side. I cleaned the outside mic cover with a toothbrush and it helped improve the sound a bit, but its still messed up.
The messed up mic is affecting phone calls and ANC and transparency mode.
Do I have to disassemble my earphones and case to clean them or do I just keep them in the rice?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Hi @noidea94846
Using rice to fix water affected electronics is a myth. It doesn't work. Rice is for dinner, not repair
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the earbuds operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your earbuds and then remove the battery as soon as possible from them to minimize any further damage.
Then you need to completely dis-assemble them and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives that may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the circuit board. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this they might possibly work correctly again.
Here is the ifixit Samsung Galaxy Buds Pro Teardown guide that may help
If this process seems too daunting, take your earbuds to a reputable, professional electronics or mobile phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Get ya the Silca gel packs off Amazon and put them back in a container for a day and try to see if that works or not and you buy replacement right ear off eBay they 25 bucks per side here’s the link hope this helps https://www.ebay.com/itm/255248521364?mk... and here’s the link for silca gel packets they will take any water out of them Dry & Dry 5 Gram [50 Packets] Silica Gel Packets Silica Gel Desiccant Dehumidifiers, Silica Gel Packs - Rechargeable (Food Safe) Moisture Absorbers, Silica Packets https://a.co/d/2ocCKhC
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
And you can reuse them also but I wouldn’t recommend taking them apart if all else fails buy the replacement
댓글 달기
귀하의 답변을 추가하세요
no idea 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 8
7일 전: 51
30일 전: 268
전체 시간: 1,562
