주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
SanDisk Cruzer Glide는 접이식 USB 단자를 갖춘 USB 플래시 드라이브입니다. 다양한 저장 용량으로 출시되며, 모든 모델이 검은색과 빨간색 플라스틱 케이스로 구성되어 있습니다.
Why is my pendrive corrupt
My pendrive is corrupt
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개:
my usb doesn't read at all
의 공유
댓글 달기
답변 3개
There are several possible reasons for a flash drive to become corrupt with the primary reasons being age and removal during a write process.
NAND flash, commonly referred to as flash storage, has a limited life span usually listed as Gigabytes/Terabytes written per year. USB flash drives do not usually list this figure, but basically the NAND flash gets worn out and has a higher chance of it having failures which will start being recognized by computers as corruption.
If a flash drive is removed before it is finished writing all the data to the flash storage it can cause data corruption. Basically when you copy something to your flash drive and you get the copy progress bar, even if says 100% complete that does not mean that it is 100% copied onto the flash storage, it ends up sitting in the storage cache. If the flash drive is removed without ejecting it from the operating system anything in the cache will be lost but the flash drive is expecting a file to be there that isn't and so you get notified of a corruption detected. If the flash drive is properly ejected the cache is flushed and committed to the flash storage to make sure everything is there.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Well this might be helpful for you to fix the issue: https://recoverit.wondershare.com/flashd...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Pendrive corrupted repair
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
What you want from your corrupted pendrive data or you need to repair any physical damage?
의 공유
댓글 달기
답변을 추가하세요
Pele jr 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 42
전체 시간: 653
