주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo 2DS는 3D 상단 화면 기능을 제외하고 Nintendo 3DS와 거의 동일한 하드웨어를 갖춘 보급형 휴대용 게임기입니다.
2ds camera error has accured
My 2ds camera works in the AR CARDS app but not in the 3ds camera and quick cam menu
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Sounds like the camera app itself is broken. Try safe mode. If that doesn't work, you'll probably have to factory reset it unless you have CFW.
If safe mode failed and you have CFW, you can try deleting the camera app, then updating the system to restore it. Launch FBI, then go to Titles > Nintendo 3DS Camera > Delete Title And Ticket. Press A to confirm, then update the console (you can use safe mode or the regular system update). The update will redownload and install the app, leaving you with a working camera
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
The 2ds I had, I had sold, thanks for the answer I will use this information if I come across this again. I will accept your answer since it “worked”
의 공유
I did this, now instead of crashing it leaves a message saying "an error has occured, hold down the power button to reset" after reseting it still just has this message.
The error popup only happens when i try to use the inner camera, the outer works fine. I have a new 2ds xl.
의 공유
Hi!
In this case you most likely need to replace the inner camera. If you need guides, please let us know!
의 공유
댓글 달기
답변을 추가하세요
Sqwerks 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 23
지난 30일: 79
전체 시간: 3,495
